1999 Acura CL Interior leaks
PRANDYB2
Air Conditioning problem
1999 Acura CL 6 cyl Front Wheel Drive 54982 miles
I am getting water leaking from the AC unit behind the glove compartment onto the passenger side floor mat. Also it is dripping onto the drivers feet.
I have checked with a garden hose on the windshield and the engine compartment fire wall. This shows no leaks.
I need to know if this is caused by a blocked drain or something internal of the AC unit.
May 25, 2010 at 12:59 AM
KHLOW2008
  • 41,812 POSTS
Hi prandyb2,
Check the evaporator drain hose for clogging or if it is dislodged.
May 25, 2010 at 1:10 AM
PRANDYB2
Thanks for the reply. Where do I look for the drain tubes on the evaporator?
May 25, 2010 at 6:04 AM
KHLOW2008
  • 41,812 POSTS
At the lowest part of the evaporator housing, under the glove box there is a drain hose that leads out to the firewall into the engine compartment.
Check if it is detached. You would need to flip the carpet out to have a better view.
May 25, 2010 at 8:10 AM
PRANDYB2
Right on the money with your answer. Detached drain tube and got the air hose and also fished a wire into the housing unit. All looks good and draining onto ground like it should. Floor and carpet drying out.
Thanks
May 25, 2010 at 11:45 PM
KHLOW2008
  • 41,812 POSTS
You're welcome and glad that you have fixed the problem.
Have a nice day.
May 26, 2010 at 12:45 AM
DONNAJ8887
[quote:ec1d7655d6="prandyb2"]Air Conditioning problem
I need to know if this is caused by a blocked drain or something internal of the AC unit.[/quote:ec1d7655d6]
Thanks you for the post.
__________________
[url=http://moviesonlinefree.biz]watch movies online[/url]
Aug 25, 2010 at 10:50 PM
