engine is at operating temperature the idle goes to 1500 RPMs?
1999 ACURA CL
133,000 MILES • 6 CYL • FWD • AUTOMATIC
VETTETOGO
When the engine is at operating temperature the idle goes to 1500 RPMs in neutral and fluctuates 500 RPMs in gear it seems to idle fine.
May 12, 2008 at 6:16 AM
  • 55,432 POSTS
This can happen when the IAC valve needs service, here is the location so you can check it out with a guide to give you step by step instructions.
https://www.2carpros.com/articles/idle-air-control-valve-service
This will need to be removed and cleaned. Check out the images (below). Please let us know what happens.
Mar 21, 2024 at 10:29 AM
  • 55,432 POSTS
anything?
May 11, 2024 at 5:48 AM
