1999 Acura CL '99 Acura Cl EGR problems
1999 ACURA CL
154,023 MILES • 4 CYL • FWD • MANUAL
PRESHANDY
My 99 cl has the engine light on for insufficiant egr flow. my car will sometimes die at a stop or when i push the clutch pedal in and has and the idle will sometimes go up and down. i have changed the egr valve out and looked down in the ports to make sure they are clear. if i clear the code it runs fine for a couple of hours then comes back on
Oct 13, 2010 at 3:54 AM
HONDA TECH 1818
  • 536 POSTS
Did you clean the port in the intake chamber?
When the idle goes up and down at idle, the IAC valve is bad.
Nov 7, 2010 at 3:16 PM
