My transmission jerks, and today I started the car and while it was on park, the drive light was flashing and when I put it in drive it still was flashing.
Friday, March 20th, 2009 AT 3:49 PM
BLUELIGHTNIN6
MECHANIC
Hello
Thanks for the donation.
The Drive indicator flashes when the computer detects a fault in the transmission. The symptoms you described is normally caused by a faulty shift solenoid, however you will need a diagnostic test ran on the transmission to pinpoint the exact culprit here.
