1998 Acura CL Transmission Fluid
130,000 MILES • 4 CYL • 2WD • AUTOMATIC
ELIZLEGRAND
I drained out my transmission fluid last night and put a 1 quart and a half to replace the drained fluid but now my car is driving rough... when i check the level of fluid its not that much, i am scared to not add too much... how much is usually the correct amount?
May 30, 2010 at 3:33 AM
KHLOW2008
  • 41,812 POSTS
Hi elizlegrand,
The drain and refill capacity is 2.5 quarts. You need to top up another quart.
May 30, 2010 at 3:58 AM
