where is the shift sensor and the solenoid b sensor?
LETTIELOVESKERMIT
where is the shift sensor and the solenoid b sensor located at in my car?
Mar 5, 2010 at 5:21 AM
These solenoids are located on the side of the unit. I am attaching the info below on how to replace this.
However, if you are going to replace the solenoids, I would suggest replacing the fluid at the same time.
https://www.2carpros.com/articles/how-to-check-and-add-transmission-fluid
Please find the info below on this and let us know what questions you have.
Thanks
Dec 16, 2021 at 12:00 AM
