1998 Acura CL Large Dent In Oil Pan
107,000 MILES • 4 CYL • 2WD • MANUAL
CHA6287
I want to know if replacing an oil pan myself is plausible and if so how is it done. Thank you
Sep 21, 2008 at 12:48 PM
KHLOW2008
  • 41,812 POSTS
Hi cha6287,
Not a very difficult job but quite messy if you don't do it properly.
1.Drain wngine oil.
2. Remove any components in the way of the oil sump.
3. Remove oil sump holding bolts and nuts.
4. Remove oil sump, if sump is stuck, use wood block and hammer to loosen.
5. Wipe off oil on base before installation. Apply sealant to curved areas of gasket before installation.
Sep 22, 2008 at 3:21 AM
