1998 Acura CL fourth gear light blinking
226,000 MILES • 6 CYL • AWD • AUTOMATIC
CHAVITO
my 4th gear light is blinking and it doesn't shift the 4th gear
Jul 26, 2010 at 2:14 AM
KHLOW2008
  • 41,812 POSTS
Hi chavito,
An error has been detected by the PCM and is indicating by the blinking D4 light.
Get a free scan done at Autozone and let me know the EXACT trouble code.
Jul 26, 2010 at 2:45 AM
CHAVITO
the trouble codes are PO758 and PO135
Jul 28, 2010 at 9:41 AM
KHLOW2008
  • 41,812 POSTS
P0135 = HO2S ( Heated Oxygen Sensor ) heater circuit malfunction.
P0758 = Shift Control Solenoid Valve "B".
Test would have to be performed to verify the source, could be a faulty sensor/solenoid . Check if any of the wireharness are loose or contaminated.
When did the Check Engine Light started showing?
It is a separate issue with the D light blinking.
Jul 28, 2010 at 11:59 AM
