1997 Acura CL Wiper Arm adjustment
208,865 MILES • 4 CYL • FWD • MANUAL
ASO333
  • 6 POSTS
The wipers on my car are hitting the A-pillar and base where they rest when they are in use. What would I need to adust or tighten to prevent this from continuing?
Jun 25, 2008 at 6:34 AM
KHLOW2008
  • 41,812 POSTS
Hi aso333,
If it is over running on both the upper and lower side, you most probably has the wrong size wiper blades. Over sized length.
Jun 26, 2008 at 3:17 AM
JEREMIAH
  • 217 POSTS
if it is making contact with both sides at the same time, the wiper assembly's linkages are worn.
unfortunately, there is no repair for worn linkages.
you will have to replace the entire wiper assembly.
Jul 5, 2008 at 5:06 PM
