1997 Acura CL Unresponsive to both remote lock/unlock
1997 ACURA CL
15,000 MILES • 4 CYL • 2WD • AUTOMATIC
RBRILL
We recently noticed that both of our remotes no longer activate (with a chirp) when we try to remotely lock or unlock the car. So we have to use the key to lock/unlock it. I suspect that due to its age some electrical component or fuse must be the source of this problem. I replaced one remote with a new battery and it still failed; the other remote is more rarely used and still failed.
I'd appreciate knowing what you think is the most likely cause of the problem, and if you believe if could be a simple electrical replacement issue.
This is the first time I've used your service and think it's a great idea. Thanks, Ron
Dec 14, 2008 at 11:15 AM
KHLOW2008
  • 41,814 POSTS
Hi Ron,
Does the power door locks operate when the door switch is activated?
First let us start with checking for power supply.
In under dash fuse box.
Fuse # 1 = 10 A
Fuse # 37 = 7.5 A
Fuse # 38 = 15 A
If these are ok, then we can try programming the remote transmitters.
Dec 20, 2008 at 9:48 PM
