Hi. I have removed and cleaned the egr valve from my 97 Acura CL 3.0. It seems pretty clean, and the exit valve seems to move out and in freely, with moderate spring tension, but no binding. Is there any further way to test this valve? Perhaps blowing or pumping air into the intake port on the valve, and see if it opens the exit valve? Would this tell me that it's functioning fine?
Secondly - Once I reinstall it, can I just disconnect the battery cable for a few seconds to reset the Check Engine Light, or will that not work?
Thanks
Jason
Thanks
Jason
Mar 1, 2010 at 7:15 PM
