1997 Acura CL stalled, no electrical power
IRONRIDERSCOTT
Electrical problem
1997 Acura CL 4 cyl Front Wheel Drive Automatic
car stalled after losing power
car acting like it has a dead battery
terminals clean, has 12 volts
Oct 20, 2008 at 3:33 PM
KHLOW2008
  • 41,812 POSTS
Hi ironriderscott,
If the dashlights are not showing, then you have a bad ignition switch.
Slowly turn the ignition key to ON, are the dash lights working? If no, the switch is bad.
Slowly turn to START, does the lights flicker?
If Yes, the switch is faulty.
Oct 28, 2008 at 6:42 AM
