1997 Acura CL Oxygen Sensor
1997 ACURA CL
PILLIT83
Engine Performance problem
1997 Acura CL Front Wheel Drive Automatic 140k miles
I need to replace the O2 sensor but I can't seem to locate it on my 1997 acura 3.0CL... please tell me where i should be looking, and if there are more than 1 sensor on this car. Thank you.
Mar 8, 2010 at 1:02 PM
BMRFIXIT
  • 19,053 POSTS
Heated Oxygen Sensor (HO2S), Primary
Below rear of engine, forward of TWC converter.
Heated Oxygen Sensor (HO2S), Secondary
On underside of vehicle, rear of TWC converter
Mar 8, 2010 at 1:11 PM
PILLIT83
Thank you!
and thanks for the speedy response!
Mar 8, 2010 at 1:36 PM
SMITH001
Hey,
UNIVERSAL OXYGEN SENSOR, HEATED, 4-WIRE -- 15 cm long wiring; Includes butt type connectors and easy-to-follow instructions; Without plug; Designed to fit screw-in type bungs; May not be compatible with flanges; Quality tested to ensure efficient fuel combustion; A high quality oxygen sensor; Features stainless steel shell, hex nut, and shield, Teflon-covered insulated wires, high-temperature rubber internal and external seals, and threaded tube coated with anti-seize compound; Helps reduce harmful emissions.
Type: Universal product, heated, 4-wire, 15 cm long, with butt type connectors
Warranty:1-year, unlimited-mileage warranty
Fits the following 1997-2003 Acura CL .
__________________________________________
[url=http://www.furnituretraditions.net/sleigh_bed.html]Sleigh Bed[/url]
Apr 12, 2010 at 8:12 PM
