1997 Acura CL fuel filter
1997 ACURA CL
170,000 MILES • 4 CYL • FWD • AUTOMATIC
OSCARROBLES1
how do you replace fuel filter and is there a special tool to remove it
May 7, 2008 at 4:10 PM
IMPALASS
  • 3,112 POSTS
Hello, it appears to be a normal wrench. WARNING: Do not smoke while working on fuel system. Keep open flame away from your work area. While replacing the fuel filter, be careful to keep a safe distance between battery terminals and any tools. The fuel filter should be replaced whenever the fuel pressure drops below the specified value [260 - 310 kPa (38 - 46 psi) with the fuel pressure regulator vacuum hose disconnected and pinched] after making sure that the fuel pump and the fuel pressure regulator are OK. Place a shop towel under and around the fuel filter. Relieve fuel pressure. Remove the engine wire harness bracket and power steering feed hose clamp.
https://images.2carpros.com/forum/automotive_pictures/248015_Fuel_Filter_1.jpg
Remove the banjo bolt and the fuel feed pipe while supporting the fuel filter with another wrench, as shown. Remove the fuel filter clamp and fuel filter. When assembling, use new washers as shown. NOTE : Clean the flared joint of high pressure hoses thoroughly before reconnecting them.
Oct 10, 2008 at 6:03 PM
