1997 Acura CL Car leaking gas
1997 ACURA CL
197,000 MILES • 6 CYL • FWD • AUTOMATIC
KAREN616
My car is leaking gas from the exhaust pipe with white smoke and also leaking gas from only one fuel injector. I did a diagnostic test and it says that I have an engine misfire.
I changed the following
Spark plugs
Fuel injector thats leaking and still is leaking out of the injector
Fuel Pressure Regulator
Oxygen Sensor
Oct 25, 2010 at 7:21 AM
KHLOW2008
  • 41,814 POSTS
Hi karen616,
Was the fuel injector replaced new or used?
Did you try swapping it with another cylinder?
Oct 26, 2010 at 12:55 AM
