1997 Acura CL Axle Replacement
RMINV
1997 Acura CL
I'm replacing a passenger-side front axle. I have the old one out and I'm trying to insert the new one into the transaxle. It's a tight fit. Is it OK to use grease on the inner spindle? Do I have to worry about this grease getting in the transaxle?
Thanks,
Tim
Aug 7, 2010 at 1:17 PM
KHLOW2008
  • 41,812 POSTS
Hi Tim,
It does not matter if some grease get into the trans.
Try turning the shaft while trying to push it n.
Aug 13, 2010 at 12:12 AM
