1997 Acura CL ABS light on
1997 ACURA CL
90,000 MILES • 6 CYL • 2WD • AUTOMATIC
ACURAUSER
After the technician changed the router anf the pad (??)...The steering wheel did not shake any more when I put on the brake pedal..but I have other problem that THE ABS LIGHT STAYED ON DURING THE CAR WAS MOVING.
I had the technician check the problem. He said he didnot cause the ABS light on..while changing the riuter/pad.
Could you please tell me what cause the ABS light on like that.?
Should I take my car to the dealer to diagnose /fix the problem (costs me lots of money)? or should I take my car to a foreing car garage to fix the problem?
your help will be appreciated very much! Please answer my question ASAP cuz the winter will come soon.
Jul 29, 2009 at 4:17 AM
  • 31,937 POSTS
Hi there,
you will ave to get a mechanic to check if these rotors have the ABS interrupter disc, and to check the air gap between the sensor and the rotor, also check that a sensor is not un plugged or damaged, scan will also help pin int this problem.
mark (mhpautos)
Jul 29, 2009 at 10:44 PM
