1995 Acura CL no air
1995 ACURA CL
12,313 MILES • 4 CYL • 2WD • AUTOMATIC
DEVELOPER7
  • 42 POSTS
ac doesnt blow any air
Apr 9, 2008 at 8:28 AM
2CARPRO JACK
  • 11,533 POSTS
Need to start by checking all fuses. Then if ok, go to blower (under dash r/h side) and using a test light check for power at the motor with the switch in all positions.If you have power, verify the ground, if it is ok as well the blower motor is bad.
Apr 9, 2008 at 8:58 AM
