1993 Acura CL headlights
1993 ACURA CL
BOBBYB
Electrical problem
1993 Acura CL 4 cyl Front Wheel Drive Automatic
how to chane inside headlights
Sep 18, 2008 at 11:49 AM
KHLOW2008
  • 41,814 POSTS
Hi bobbyb,
You sure you got the year correct? The first model CL appeared only in 1997.
You meant to replace the halogen bulbs?
Sep 19, 2008 at 2:38 AM
PARKOURISM
open up the hood and look behind where the headlight is located. If it's on the driver side it will be hidden by the battery and the battery will need to be removed. If it's on the passenger side you should see a small round compartment that has some kind of high voltage warning on it. Ignore this and remove the cover. The headlight should be held in by a metal clip and a bolt, remove these and the headlight should be right there.
Jul 16, 2009 at 10:43 AM
