crankshaft position sensor location
200,000 MILES • 3.2L • V6
JOE MARTIN2
Where is my crank sensor?
Oct 19, 2018 at 5:58 AM
CJ MEDEVAC
  • 11,000 POSTS
Here is the location for the crankshaft sensor. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Oct 19, 2018 at 1:23 PM
JIMMIEBOY
Hi I need help locating the crank position sensor on a Acura cl type-s thanx
Dec 3, 2020 at 12:34 AM (Merged)
JIMMIEBOY
Thanx for your response and I found it. I had to change the timing belt anyway and found the sensor behind the crank pulley behind the timing belt plastic cover. The car I'm working on is a 2001 automatic Acura cl type-s.
Thanx again
