Blend door actuator locations
100,000 MILES • 6.0L • 4WD • AUTOMATIC
DEBBIE HOWLE
How many actuators are in climate controls AC/Heat. The fan will not blow.
Sep 30, 2017 at 1:42 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
It sounds like you are having an issue with the blower motor if it is not blowing any speeds. Here is a tutorial showing how to replace a blower motor:
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
The blower motor is located in the hvac box under the dash on the right side. I've attached picture steps below showing blower motor replacement on your vehicle. Hope this helps and thanks for using 2CarPros.
Jan 27, 2021 at 11:09 AM
