4 wheel drive not working
230,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
NORMAN KASINGER
  • 5 POSTS
Actuator going in and out 4low when it is in 2WD.
Nov 15, 2018 at 5:11 PM
  • 55,781 POSTS
It sounds like the encoder motor is going out. Here are instruction and diagrams to help you replace it below:
INSTALL OR CONNECT
1. Any gasket material remaining from the motor/encoder.
- New motor/encoder should have a new gasket attached.
2. Four bolts securing the motor/encoder to the transfer case.
- Ensure the motor/encoder aligns properly with the transfer case interior shifting components.
- Align the motor/encoder mating surface detents with the transfer case mating surface detents.
- Tighten motor/encoder bolts to 25 N.m (18 lb ft).
3. Wiring harness connectors to the motor/encoder.
4. Transfer case shield.
5. Negative battery cable.
6. Perform a functional test on the electronic shift select system to test the motor/encoder.
Cheers, Ken
May 14, 2021 at 4:19 AM
NORMAN KASINGER
  • 5 POSTS
Okay thank you. So it is the actuator?
NORMAN KASINGER
  • 5 POSTS
Okay, I have a 1999 Suburban will the parts interchange?
NORMAN KASINGER
  • 5 POSTS
And I see now what you were talking about. Thank you
  • 55,781 POSTS
It should work if the parts numbers are the same. Please let me know how it goes.
