actuator blend door parts
150,000 MILES • 6 CYL • AUTOMATIC
CHRISTIAN FLORES
My heat is not working and while checking I discovered there is a metal link missing from the actuator door system. It is the part that is supposed to move when the temperature knobs are moved from hot to cold. I have been trying to find the part but have had no luck. I think that is the only issue so I want to avoid buying the vent door actuator when I am not seeing the link on the product descriptions. Is there a place where I can find the part of even the specs so I can 3d print one?
Dec 26, 2016 at 3:57 AM
SATURNTECH9
  • 30,868 POSTS
It is part of the bleed door dorman makes a repair kit dorman part number 902223.
Dec 26, 2016 at 4:19 AM
CARADIODOC
  • 34,417 POSTS
That is what salvage yards are for. Look for one where you bring your own tools and dig up your own parts. Do a search for "Pull-A-Part" to see if they have a yard near you. I have been to sixteen of them. All are very clean and well-organized. Parts are cheap and the employees and customers have always been very friendly. You pay your buck, then you can spend all day there taking things apart. There are many other similar yards popping up all over the country, but none are as well-organized as these.
Dec 26, 2016 at 4:21 AM
SATURNTECH9
  • 30,868 POSTS
The dorman part allows you to repair it through the glove box instead of taking everything apart.
Dec 26, 2016 at 4:39 AM
CARADIODOC
  • 34,417 POSTS
Thanks Saturntech9. As usual, I was busy typing while you were already posting your dandy reply. You are truly a wealth of wondrous information.
Dec 26, 2016 at 6:45 AM
SATURNTECH9
  • 30,868 POSTS
Thanks cardio your a wonder of information yourself.
Dec 27, 2016 at 4:30 AM
