Actuator blend door
2014 HYUNDAI SONATA
137,000 MILES • 2.0L • TURBO • 2WD • AUTOMATIC
PATRICKNKERISHA PARKER
Need to replace, no diagram. The passenger side blows cold air the driver side does not. Do you have an idea what the problem is?
Jun 7, 2018 at 12:08 AM
Good afternoon.
Procedure and pictures below for your repair.
Replacement
1. Disconnect the negative (-) battery terminal.
2. Remove the crash pad left side cover (A).
imageZoom/Print
3. Remove the extension cover.
4. Remove the crash pad lower cover (A).
imageZoom/Print
5. Disconnect the connector (A) & diagnosis connector (B) and then remove the crash pad lower cover.
imageZoom/Print
imageZoom/Print
6. Remove the reinforcing panel (A).
imageZoom/Print
7. Remove the shower duct (A).
imageZoom/Print
8. Remove the BCM (A).
imageZoom/Print
9. Disconnect the temperature control actuator connector (A).
10. Loosen the mounting screw and then remove the temperature
Jun 7, 2018 at 3:07 AM
