Actuator
150,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
GOLDENPAINTING
Went to switch from 4 low to 4 high. Nothing engages now. Even rolls while in park. Could it be both drives we're disengaged ? Is this an easy fix ?
May 18, 2019 at 8:38 AM
Good afternoon,
Is this a stick or automatic transmission?
May 18, 2019 at 9:11 AM
GOLDENPAINTING
Automatic.
May 18, 2019 at 10:30 AM
It sounds like you have a transmission issue if you cannot get it to lock into park.
did you check the cable to the transmission to be sure it is connected?
May 18, 2019 at 11:18 AM
