Transmission shifts into gear, it just does not move?
200,000 MILES • 4 CYL • 2WD • MANUAL
TENACITYREBORN
Seems to go into gear right, it just doesn't move. The clutch is in good shape. I would like to think I don't necessarily have to get a transmission.
Oct 8, 2022 at 7:44 AM
  • 110,248 POSTS
Chances are it's not the transmission. If you place it in gear with the engine off and clutch released, are you able to move the vehicle? Also, does the clutch pedal feel normal?
Keep in mind, the clutch is actuated by a cable. Check to make sure nothing is preventing it from releasing. See pic below
Oct 9, 2022 at 9:46 AM
