AC,Speedometer guage and ABS not working
33,000 MILES
PRINCEPAP
I'm having AC, Speedometer, ABS problems with my 2013 Corolla. I took it to an AC technician to fill the AC gas and he tampered with the system of my car. AC light is not coming up and not working, speedometer guage is not functioning, ABS light on .Computer don't seem to identify the problem. the car is not in good shape. Please help.
Feb 13, 2016 at 3:15 PM
WRENCHTECH
  • 20,758 POSTS
I doubt that problem is related to the AC issue. You probably6 have a bad speed sensor somewhere. You need to have the codes read in the ABS module for a starting point.
Feb 13, 2016 at 9:03 PM
PRINCEPAP
Thank you for your response. Tried using the computer to detect the problem, it does not work. The mechanic told me i need to change the ABS and it cost about $600. Is the ABS module different from the ABS pump. please envisage on this. Thanks a lot.
Feb 14, 2016 at 5:16 PM
WRENCHTECH
  • 20,758 POSTS
The ABS module and pump are 2 different things but likely sold as one part that is not sold separately.
Feb 14, 2016 at 5:58 PM
PRINCEPAP
Okay thank you. Is it the speed sensor that's bad or the ABS module. Please elaborate on this. Thank you.
Feb 16, 2016 at 2:43 PM
WRENCHTECH
  • 20,758 POSTS
I can't tell you that. I'm not the one that scanned the system.
Feb 16, 2016 at 5:56 PM
