Will not stay running
2001 ISUZU RODEO
150,556 MILES • 0.6L • 6 CYL • 4WD • AUTOMATIC
AMANDA M KELLY
I already changed fuel filter. Seem to help. Put code reader on it no codes. Why will it not stay running? I can shut it off for around five minutes and it will not shut off for a minute.
Sep 29, 2018 at 5:40 AM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
It could be a weak/failing fuel pump. I would suggest pressure testing the fuel pump. If you do not have access to a pressure tester your local auto parts stores have a tool loaner program and will rent you one. Your fuel pressure should be 47 P.S.I. at Idle. I have attached a tutorial showing how to test. Hope this helps and thanks for using 2CarPros.
Danny-
Sep 29, 2018 at 10:06 AM
