Acceleration problem
25,850 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
ROCOELHO
  • 6 POSTS
My car Mitsubishi Dion. It will not go over 2,500 rpm's.
Dec 10, 2018 at 4:42 PM
  • 55,721 POSTS
Is the check engine light on? It sounds like you have a clogged catalytic converter but to be sure lets run down this guide:
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
This guide can help as well:
https://www.2carpros.com/articles/engine-has-low-power-output
Cheers, Ken
Dec 12, 2018 at 2:45 AM
ROCOELHO
  • 6 POSTS
Hi Ken,
Note that check engine light is not on but I will try as per you explanation, and revert back to you.
Thanks
Dec 12, 2018 at 12:44 PM
  • 55,721 POSTS
Please get back to me with the results.
Dec 14, 2018 at 1:31 AM
ROCOELHO
  • 6 POSTS
Thank Ken,
I will do that.
Dec 14, 2018 at 2:34 PM
ROCOELHO
  • 6 POSTS
Dear Ken,
Note that I have try to change the clogged catalytic, but still doing the same!
Dec 28, 2018 at 2:11 PM
  • 55,721 POSTS
How is the fuel pump or fuel filter? Let's test the fuel pressure and fuel filter. here is a guide to help walk you thought he steps you can rent a gauge for free at the auto parts store:
this guide can help as well:
Dec 29, 2018 at 3:12 AM
ROCOELHO
  • 6 POSTS
Thanks ken,
The problem is I don't know the location of the fuel filter .
Mitsubishi DION 2000 Year 2005
Dec 30, 2018 at 3:10 PM
  • 55,721 POSTS
It should be back at the fuel tank, follow the fuel line from the tank to the engine.
Dec 31, 2018 at 3:02 AM
ROCOELHO
  • 6 POSTS
Thanks Ken,
I will do that and let you know!
Jan 1, 2019 at 12:28 PM
