New actuator failed in just a couple of days
86,000 MILES
JBOS
I installed a new actuator on Monday and everything was fine, but on Wednesday morning car would not start because actuator would not stop. Why is it running when car is off?
Oct 11, 2016 at 10:47 PM
HMAC300
  • 48,601 POSTS
cold be a cheap actuator and failed. try pulling HVAC fuse inside car for sixty seconds with key on see if it resets that may take care of it. if not then have scanned for codes by a mechanic may be something else.
Oct 11, 2016 at 11:50 PM
JBOS
It is not the actuator after all. I disconnected it and when tried the key. Nothing happens. When you take the key out it was making the same noise. Sounded like things were trying to run. I went to a mechanic shop to see if he had any ideas and he thought maybe the battery was low so I am trying to charge the battery.
Oct 12, 2016 at 1:25 AM
HMAC300
  • 48,601 POSTS
after the battery is charged have it tested including load test most places do for free.
Oct 12, 2016 at 2:19 AM
RENEE L
  • 1,260 POSTS
Hi JBOS,
If you decide to check the condition of your battery yourself here is a link to helpful information from this site that features written instructions, pictures and a video explaining how to load test your battery yourself.
If you need further assistance please come back to 2CarPros.com. We are always happy to help.
https://www.2carpros.com/articles/how-to-check-a-car-battery
Thank you for visiting 2CarPros.
Kindest regards,
Renee
Admin
Oct 12, 2016 at 6:47 AM
