Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Silverado
Drivetrain
Differential
Replace/Remove
Accidentally changed front diff and added ATF instead of Gear Oil
2007 CHEVROLET SILVERADO
150,000 MILES • 6.6L • V8 • TURBO • 4WD • AUTOMATIC
MESSEDUP
MEMBER
1 POST
Could you please tell me what problems I may encounter after driving my truck in 4WD on ice for 500 miles with ATF in the front diff?
Jan 21, 2015 at 6:08 AM
HMAC300
Experienced Mechanic
probably not a lot. just put the correct stuff in and then see if you hear anything normal I'd doubt you will.
Jan 21, 2015 at 7:08 AM
I agree with HMAC300, here is how to change the differential oil and add the correct fluid to help you.
SAE 80W-90 GL5 Lubricant
Check out the images (below). Let us know if you need anything else.
Image (Click to enlarge)
Oct 10, 2024 at 10:35 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
