After an accident will not start
44,000 MILES • 4 CYL • AUTOMATIC
REMY GREEN
Got into a small accident. I did hit a rail head on but no major damage. Not even to the body. Just some scratches. But everything looks and works fine engine just will not turn over. As I turn the key it makes the start up sound then just stops and there a click. Not rapid. Lights and music works. Car just will not turn over. Help please. Cannot afford a shop.
Nov 10, 2017 at 8:15 PM
KHLOW2008
  • 41,812 POSTS
Hi Remy,
Have the battery tested and check the battery terminals to see if they are clean and secure. Try a jump start. Lights working does not mean that there is nothing wrong with the battery because lighting systems do not work on high current draw whereas the starter does.
If you have a volt meter, check the battery voltage. Get someone to crank the engine and note the voltage drop. If it drops below 11 volts when the ignition is being cranked, it means either the battery is weak, bad or the connections are loose.
Nov 10, 2017 at 10:12 PM
REMY GREEN
Yup jump start worked. Thank you! Been looking for a shut off switch all morning to find out there is not one and this simple answer saved me hundreds. Truly thank you!
Nov 10, 2017 at 10:21 PM
KHLOW2008
  • 41,812 POSTS
You are welcome.
Have the battery tested. It could be failing or it could be a problem with the charging system.
Have a great weekend.
Nov 10, 2017 at 10:49 PM
