Accident, wanting to know if maybe damaged radiator or not
168,000 MILES • 4 CYL • 2WD • AUTOMATIC
PATTIE FLYNN
Run into back of another car and tow bar bent my front bumper bar and plate and I'm not 100% sure if did any damage to radiator or not... The bar is very close to the front fan of the radiator.
May 10, 2022 at 6:34 PM
BORIS K
  • 836 POSTS
First, I would suggest you visually see if any part of the bumper bar has touched the radiator.
Is the radiator deformed in any way?
Next, I would recommend a cooling system pressure test and check for leaks while the system is under pressure. Also check if the pressure falls off, indicating a possible leak in the cooling system.
How to pressure test cooling system.
https://www.2carpros.com/articles/radiator-pressure-test
Hope this helps.
Cheers, Boris
May 10, 2022 at 7:01 PM
