Accentuator not working properly
65,000 MILES • 6 CYL • 2WD • AUTOMATIC
BEELEWIS930
Clicking noise whenever I open the car door to get in or out. Clicking noise stops as long as I keep the A/C turned on High. I've seen the videos on how to locate the accentuator behind the glove box. My question is, if I just remove the one that's making the clicks without replacing a new one, will my A/C still work?
Sep 6, 2021 at 12:47 AM
  • 110,248 POSTS
Are you referring to the blend air door actuator, the A/C accumulator, or something different? The blend door actuator is what controls the air temperature entering the vehicle, so that is needed, and the accumulator is part of the low-pressure system which is responsible for both oil and Freon return to the compressor. You need both.
Here is a guide that will help with this.
Let me know if it is something different.
Sep 6, 2021 at 12:14 PM
