Does not start
120,000 MILES • 1.5L • 3 CYL • MANUAL
JIJEESH
(CRDI). All injector working okay, ckp and cmp sensor okay, high pressure pump also good condition. but would not start this moment
vehicle garage coming good working, only one problem engine overheat and head facing, gasket replace timing also corrected. please help me.
Nov 8, 2017 at 10:03 PM
  • 31,937 POSTS
Do you have any codes? check with code reader not all code set a check light. do you have spark? did you do the head gasket and was this a recent problem, is it not starting since doing the head gasket?
Nov 9, 2017 at 7:32 AM
JIJEESH
complaint code u0008.,u003
Nov 12, 2017 at 7:46 PM
  • 55,721 POSTS
Those are communication codes so one of the computers is not talking for some reason. I would start by checking all system fuses. If one of the computers is not getting power it will cause this error.
Here is a guide and some diagrams of the fuse box (below) so you can do some testing.
Please check all system fuses with the key "on"
Please run this test and get back to us.
Cheers, Ken
Nov 15, 2017 at 10:20 AM
JIJEESH
sir,all wiring harness replaced,rail with sensor,h p pump and cylinder head ,Ecm also.. ....
but engine starting few times(10 second)also.this time
engine dtc check no trouble code,engine again start not starting and dtc check U0003,and U0018,some time U0008 .
sir no replace parts this category .only balance for engine block,timing belt
Nov 16, 2017 at 2:15 AM
  • 55,721 POSTS
All communication errors. Please check for power at each of the fuses and make sure the relays are working. If everything checks out check the power and grounds at the computers because something is not working or powering up. This car is diesel correct?
Cheers, Ken
Nov 16, 2017 at 2:53 AM
