Car jerking, lost acceleration and engine light turned on
175,000 MILES • 1.6L • 4 CYL • AUTOMATIC
PRAIRIESTROX
Accelerator Pedal Sensor or CVT Transmission? Used a Diagnostic scanner code was for low CVT Fluid. Got the refill done. Car still jerking and no RPM.
Dec 2, 2019 at 3:24 PM
AL514
  • 5,700 POSTS
Hello, the no rpm signal indicates a problem with a crank sensor. It's the input for the rpm signal to the computer. Try re-scanning the computer and see if anymore codes come up. And if you have the means to watch the crank signal on your scan tool, that would help in diagnosing the problem.
Dec 2, 2019 at 8:47 PM
  • 55,721 POSTS
It sounds like the engine could be missing or you need to service the throttle bore. here are three guides to help us:
and
and
Please run down these guides and report back. Can you please shoot a quick video with your phone so we can see what's going on, that would be great. You can upload it here with your response.
Dec 4, 2019 at 12:16 PM
