Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Crown Victoria
Interior
Gas Pedal
Sensor
Replace/Remove
Accelerator pedal not working
2010 FORD CROWN VICTORIA
226,000 MILES • 0.5L • 6 CYL • 2WD • AUTOMATIC
MARSHA50
MEMBER
I replace the pedal sensor, but it still will not work.
Sep 28, 2019 at 8:34 AM
Experienced Mechanic
Good evening.
Is that the issue? Were there any codes set for this? If there was, I need the code.
The TPS is the most common issue for no throttle response.
Beyond that, the throttle body may have to be replaced.
Images (Click to enlarge)
Sep 28, 2019 at 9:07 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
