Accelerator not the same since exhaust repairs
2001 FORD MUSTANG
200,000 MILES • V6 • RWD • AUTOMATIC
BANANNA
I took my car for repair and had the passenger side exhaust manifold and gasket replaced. However I now notice a significant change in the performance of my gas pedal. Its hard to explain really. I used to be able to "gun it" and my car would shoot off nicely. Now I can not use the same pressure I am used to because it feels like the pedal hits the floor or is hitting something. It also now takes time to reach speed it didn't before .
Before I call the shop to inquire about what they messed up. I need info on what they could have done to alter my performance. What could they have messed with that would ruin my performance?
Dec 13, 2014 at 1:43 AM
HMAC300
  • 48,601 POSTS
before you blame the repair shop check to make sure your gas pedal isn't obstructed by carpets, etc. that happens a lot. if anything is screwed I=up it may be a smaller manifold was installed or there is something else wrong that had previously went unnoticed. scan for codes and check fuel pressure with a gauge auto parts rent it.
Dec 13, 2014 at 2:16 AM
