Accelerator failing to respond or slows down
130,000 MILES • 1.6L • 2WD • MANUAL
STEPHEN S
Accelerator simetimes fails to respond when you start the car, when put off for sometime and restarts it respond. Again at times when on wheel the car slows down with the accelerator not responding. In such situstions I wait a while restarts and it works. It also jerks while wheels. At least three mechanics have attempted maintaining it but it is still a problem. Please all forms of support needed. Thanks
Mar 23, 2018 at 10:52 PM
  • 55,694 POSTS
It sounds like you have a throttle pedal position sensor that is going out but to be sure lets start by running the codes. Here is a guide to help us get started:
What did the other mechanics try or replace to fix the problem?
Cheers, Ken
Mar 26, 2018 at 2:49 AM
