Limp Mode
135,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
ERVIN WHITE
My accelerator not responding when l mash it.
Oct 11, 2018 at 12:36 AM
  • 55,740 POSTS
It sounds like the engine is in limp mode because of a computer issue. Lets start by running the codes to see what come up so we can go from there to fix the car. Here is a guide that will help you:
Cheers, Ken
Oct 12, 2018 at 3:47 AM
ERVIN WHITE
Did the diagnostics and the code P2128 and P0435 came up.
Oct 14, 2018 at 6:55 AM
  • 55,740 POSTS
The code P2128 is telling us you have a problem with the throttle actuator. I would try cleaning it first. Here is a guide. Disconnect the battery before you begin and clear the codes once completed.
Oct 15, 2018 at 4:10 AM
