Acceleration problems
100,000 MILES • 4.2L • 6 CYL • 4WD • AUTOMATIC
RODNEY CAR CARE
The car sounds rough when I start it, when I take off it it moves slow (creep) then just kicks in and rides smooth, it never goes above 30 mph and if I try to push it pass 30 mph it start to shake like it wants to cut off. I have changed the coil pack, the cam censor, and the acceleration pedal. Still no change, please help me.
Feb 3, 2019 at 10:44 PM
  • 55,709 POSTS
It sounds like you are in limp mode due to a dirty throttle bore. Here is a guide to help us fix the problem:
https://www.2carpros.com/articles/reduced-power-limp-mode
We should run the codes as well.
Feb 5, 2019 at 3:36 AM
