Acceleration problem
200,000 MILES • 3.5L • 6 CYL • 4WD • AUTOMATIC
ABDUL BASITH MJ
I bought the vehicle listed above which was stopped for a long time. I charged the battery and it did not work, so I asked a local mechanic and he said the fuel pump is gone, so I got it replaced with one from scrap. Then it worked fine for a day, next day it started accelerating slowly and even it gets turned off sometimes. I asked two mechanics locally and one of them told me it's the fuel pump motor and other said fuel filter.
Any idea why is this happening?
Jul 15, 2021 at 2:32 AM
SQM
  • 6,383 POSTS
This could happen for several different reasons. You could have a clogged in the fuel line/filter. Could have a fuel hose that might have collapsed.
Have you checked the fuel pressure?
Here is a guide on how to check fuel pressure:
https://youtu.be/peh7-pFycyc
https://youtu.be/aITQclp7zIE
Is the check engine light on? If so do you know the codes?
https://youtu.be/ahK_eucFi-k
Here is an article you might find helpful:
https://www.2carpros.com/articles/symptoms-of-low-engine-power
Check out this video as well:
https://youtu.be/U1RoG3I-Oww
https://youtu.be/dCjmRL3p4Cs
Let me know of any questions.
Jul 15, 2021 at 2:45 AM
