Acceleration problem
130,000 MILES • 2.5L • 5 CYL • FWD • AUTOMATIC
YAPEDO1
when the rpm's hot 3000 the car stops accelerating and when I press on the throttle more it starts to jerk, I have to take my foot of the throttle and let the rpm's go down before I can accelerate again. What could be causing this problem?
May 10, 2016 at 1:47 PM
  • 55,583 POSTS
Hey YAPEDO1,
It sounds like one of two things are happening, either you have a cat that is plugged, or the fuel pressure is weak, here are two links that can give you an idea on how to test for these problems,
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
and
You will need to tap into the fuel line at some point to check the pressure you can get the tester from Amazon if you don't have one.
Let me know what you find.
Best, Ken
May 17, 2016 at 2:22 AM
