Acceleration noise. Cause for concern?
161,000 MILES • 3.5L • 4WD • AUTOMATIC
RONWHIT
2016 Honda Pilot EXL. After braking and sometimes after being on the throttle, I let go and then re-engage the throttle. I hear a pshh sound for a second. It sounds like it's engine related and right in front of me.
I can make it happen but at the same time it's dependent on if the car is under load like going uphill. Is this normal?
Nov 13, 2026 at 7:09 AM
MECHTRIX
  • 590 POSTS
Here are a few things that can make that sound
Many times the throttle body can make that sound if excelerating abruptly .. also somtimes if an exhuast gasket or joint is leaking it can make that sound upon speeding up or slowing down
Leaky manifolds can whistle
Check around the engine bay
The main things to pay attention to would be weather or not it gets worse gets louder starts to do it more frequently if it does have it inspected by a reputable mechanic good luck hope this helps
Nov 13, 2026 at 6:10 PM
RONWHIT
Ok, thank you!
Nov 13, 2026 at 7:52 PM
  • 55,721 POSTS
MECHTRIX is a good car repair person. Let us know if you need anything else.
Nov 15, 2026 at 7:18 AM
