Acceleration issues chugs and jerks every now and then?
180,000 MILES • 5.4L • 4WD • AUTOMATIC
LELANDGRACY
My truck has issues when accelerating. It chugs and jerks every now and then when speeding up and the issues only seems to get worse. I stick with unleaded fuel but if you put super unleaded it gets worse. The check engine light pops on and off but now it’s not coming off. When you accelerate and it jerks, if you press more on the gas pedal it stops. It’s sometimes idles rough and shakes. A family friend believes the catalytic converter is getting clogged but I’m just not sure. It’s the Harley Davidson edition if it matters.
Nov 3, 2026 at 8:08 AM
  • 55,684 POSTS
Hello, it sounds like the engine is misfiring, lets run the codes to see what is going on, this video can help us get started.
https://www.youtube.com/watch?v=LBCpCWEFnTg
Worn spark plugs or a failing ignition coil can cause jerking under acceleration, but we need the trouble codes before recommending parts. What exact codes are stored, and when were the spark plugs last replaced? A short video of the problem will hep us fix it as well.
Nov 4, 2026 at 7:40 AM
