Acceleration issues
140,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
ADAMGPALL
I am having trouble while driving after I get up to around thirty five to forty mph it seems like the engine or rpm's bog down and really will not speed up even if I press the gas all the way. I think when I do so the rpm's climb but the truck does not speed up. Also, you should probably know that the exhaust has a huge hole in it before the catalytic converter. Even after I patched the hole temporally it did not seem to help the acceleration issue. There is also a check engine light on but do not know what the codes are. This problem happen over eight months ago, but have not had the money to fix it so it has just been sitting because the inspection will not pass do to the check engine light.
Is my transmission going or gone?
Jan 13, 2018 at 5:48 AM
HARRY P
  • 2,292 POSTS
Take it to the local AutoZone, Advance Auto, O'Reilly Auto, or Pep Boys and have it scanned. They will give you the codes for free. Come back with those code numbers and we will see what is what. Yes, it could be the transmission, but I have never seen a Blazer with transmission problems with only 140,000 miles on it. And I have personally owned five of them, and have bought and sold dozens of them over the years. Get those code numbers.
Jan 13, 2018 at 8:01 PM
