Acceleration issue - Traction Control Hesitation?
100,000 MILES • V8 • 4WD • AUTOMATIC
ABUENO
From a stop, when I hit the accelerator, the truck begins to move and then hesitates and the traction control kicks-in briefly. When I let off the gas a little, the issue clears and I can then accelerate as normal. If I turn off the traction control, then the issue does not occur. Any thoughts? Thanks.
Dec 26, 2025 at 7:41 AM
STEVE W.
  • 15,399 POSTS
See your other post about the noise, TC uses the same sensor system as the ABS unit so any issues with them creates a problem in the traction controls as well.
Dec 27, 2025 at 12:05 AM
ABUENO
Appreciate the feedback, Steve. Was curious if the two might be related, which at least leaves less to diagnose. Thanks!
Dec 27, 2025 at 2:09 AM
  • 55,682 POSTS
STEVE W. is one of our best! Please let us know what happens and use 2CarPros anytime.
Dec 29, 2025 at 1:16 AM
