I’ve replaced the throttle body control and the gas pedal and it still won’t accelerate past 15
Jan 3, 2026 at 7:03 AM
STEVE W.
✓Experienced Mechanic
There are multiple items that can trigger reduced power mode. Do you have a scan tool that can pull codes from every system? Even if the CEL isn't on there can be codes in other systems that can trigger reduced power. As such a scan is the first step. https://www.2carpros.com/articles/can-scan-controller-area-network-easy
