Acceleration issue, check engine light on
JEFAFA
  • 1998 FORD ESCORT
  • 2.0L
  • 4 CYL
  • 167,155 MILES
Bogging down pretty much right off the bat. I have no acceleration starting in drive. As soon as I try to press on the gas pedal it doesn't go anywhere and this is a new development. I've done the basics when I first bought the car like oil change including oil filter, new battery, new air filter, new spark plugs, new spark plug wires, new fuel filter, new thermostat, new front 02 sensor bank 1 sensor 1. I had the transmission fluid changed by jiffy lube and they also rotated the tires. They have done two oil changes in the time I've own the car. I do have a check engine light on and it says it's the same 02 sensor I switched out unfortunately I have noticed it is melting at the plastic connection piece. Although I don't think the issues is the 02 sensor. But one thing I have noticed is my oil light does come on and it does flicker but I don't understand it and don't know what to do about it. I don't really know much about cars usually just the basics of what I've said I've done already.
Thursday, January 24th, 2019 AT 7:56 PM
  • 52,797 POSTS
Good morning,
There are many possibilities and I will list a few that need to be checked.
1. Fuel pressure. You need to verify the actual fuel pressure to be sure the injectors have sufficient pressure to work.
2. Catalytic converter being clogged. You need to have the back pressure tested to be sure it is not allowing the engine to breathe.
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
3. Timing. The valve timing from either the timing belt or chain. If it is worn out and it is slacked, it could give you these symptoms.
https://www.2carpros.com/articles/how-a-timing-belt-works
As far as the oil light, you need to have someone test the oil pressure with a manual gauge to be sure there is sufficient pressure to lubricate the engine bearings.
Friday, January 25th, 2019 AT 5:20 AM
JEFAFA
Thank you for your timely reply I appreciate it. And I will definitely take your advice and get these parts looked at with a trained eye yet before I seen your response I had put in a new ignition coil and it seems to have solved it but I am taking your advice seriously and going to have the rest looked at and thank you for taking the time and effort to reply
Friday, January 25th, 2019 AT 10:53 AM
  • 52,797 POSTS
Sounds like a plan
Your Welcome
Always glad to help
Friday, January 25th, 2019 AT 11:06 AM
