accelaration trouble
1999 RAM 1500
157,000 MILES • 5.9L • V8 • 2WD • AUTOMATIC
JAXS
my truck listed above 360 is hard to start and when you push the gas you have to
pump it to make it go and pedal almost all the way to floor it does this when
idling also.
Jul 17, 2021 at 1:20 PM
SQM
  • 6,383 POSTS
There could be few reason for the hard start. It could be fuel or ignition related.
Is your check engine light on? If so what are the codes?
https://youtu.be/vMwTzURWXmk
https://www.2carpros.com/articles/engine-cranks-excessively-before-starting
For the gas pedal issue, is this something that started to happen the same time hard start began?
I would really like to know if there are any trouble codes. That could point us to the right directions.
Please let me know.
Jul 17, 2021 at 2:18 PM
JAXS
No codes. I was told ask this: why do I have to pump my gas pedal a bunch to get it go normal speed?
Jul 17, 2021 at 2:29 PM
SQM
  • 6,383 POSTS
If you are parked and press the pedal, does the engine RPM rises as it should? Or do you have to go all the way down?
Jul 17, 2021 at 2:39 PM
JAXS
They rise normal I believe but my gas pedal almost to the floor after pumping it a million times to get it to go good.
Jul 17, 2021 at 2:42 PM
JAXS
It like sputters and backfires through the breather box.
Jul 17, 2021 at 2:43 PM
I have seen this a number of times on this engine. It is normally a MAP sensor issue but could be weak fuel pressure or even restricted exhaust.
What you are doing with pumping the gas is nothing more then opening the throttle, as the injectors are controlled by the PCM. If is running better then you have an imbalanced air/fuel ratio and as you open the throttle it is allowing more air in and then closing it, it lets less air in. So we need to know which way the ratio is imbalanced. Is it rich or lean? You can tell this by monitor o2 sensor data/voltage.
Here is a guide that covers the two major causes which are MAP sensor or fuel pressure:
https://www.2carpros.com/articles/engine-backfires-while-running
If you have a scan tool that can monitor the data can you tell us what the MAP is reading while this is happening and with the key off?
We then need to know what the fuel pressure is to find out if that is the cause. So let us know what the pressure is using this guide.
If the fuel pressure is okay, I would replace the MAP sensor just based on experience so I provided the info from the manual below.
Please let us know what you find on this. Thanks
Jul 18, 2021 at 7:39 AM
